Login form needs to distinguish between bad email and bad password
Thread begun 11/03/2010 1:50 pm by SaladoGuy | Last modified 3/22/2011 4:51 pm by Lon Winters | 9511 views | 14 replies |
SaladoGuyBeta Tester
To continue my thread about user problems with the login form (showthread.php?t=16940)...
Right now, on the login page, if the user inputs an incorrect email address, they are immediately sent to the "Forgot password?" password reset page which confuses them because then they think their password is wrong even though it's the email address that's wrong (I've had some users get rather disturbed about this behavior).
So I need to either 1) Redirect them to a different page (other than the bad password reset page) when the email address is wrong, or else 2) redirect them to the same page but have it display a different message depending on exactly what's wrong: the email address or the password.
Problem is I don't know how to do either of the above. I tried using WA "Validator" to check the email address field against all a recordset containing all the emails in the customer table (surely that's not a good way to do that! Imagine facebook or amazon doing something like that ...) and configured the Validate server behaviour to redirect to a different page (customer_bademail.php) but it doesn't work, they still get sent to the "bad password" page.
Could someone please tell me how to detect an invalid email address (meaning, one that isn't registered in the system) and print a different message or redirect to a different page?
Thanks!
you are on the right track using validation toolkit.
Create a recordset that filters the email address column against the entered email address.
then add the validation Toolkit Server Validation behavior.
Select number validation.
set the server variable to:
$totalRows_<recordset name>
where <recordset name> is the name of your recordset.
set the minimum number to 1, set the maximum to 10000
Hi Jason,
I'm still having a little trouble with this. First:
What I did is create the recordset (simple view) to use the customer table, use only the email colum, and Filter by "email"(column) = Form variable "username" (I called that form field "username" way back when I first generated the page with SecurityAssist
Was that the right way to configure the recordset? Or should I have used "Entered Value" instead of "Form varible"?
Next, it was still redirecting to the "bad password" page even when the email address was bad.
I tried moving the php code up from where it was (it was formerly underneath the Security Assist "Authenticate user" block of code) up to the top. I thought maybe php was processing the "Authenticate user" block first and preempting the bad-email detection.
Unfortunately, after that, now I get sent to the "bad email" page even when I use a valid email and password.
Could you look at it and tell me what I did wrong?
Another thing:
When I created the validate server behavior, at first I used the "dynamic" (lightening bolt) menu to choose the recoord set and the code looked like this:
$row_rsCheckEmail['email']
I also tried changing $rows_ to $totalRows_ as you described but it did not help.
I moved the Validate code block back down to where it was previously. Now I can log in again with a good email and password, but still when I use a bad email it sends me to the bad password page.
I've attached the new version here also.
Originally Said By: SaladoGuy
Really attached this time.
1) the code order on the page was not correct.
2) The server variable to use for the validation is:
$totalRows_rsCheckEmail
not:
$totalRows_rsCheckEmail['email']
I have attached the corrected file.
danny405167
How abnout the password
I follow your instructions on how to filter the email address to check if is a registered email address. I tried to do the same with the password but no luck because the passwords in the database are encrypted. Can this method be used to check if the password is good or bad?
yes this can be done.
when creating the parameter for the password look up recordset, set the run time value to:
sha1($_POST['passwordElement'])
where passwordElement is the name of the password form element.
Lon WintersBeta Tester
My 2 cents
Checking for the existence of a user name during a sign up process is good to have. But it's not a good idea for a login form. Most logins you see on websites just tell you that the login failed, and give you options to retrieve you info.
For security reasons, if you tell the user which one of the fields doesn't validate, it just makes it that much easier for someone to hack into the account.
Plus it makes your job easier as this is the default way the login behaviors work. Just something to think about.
Excellent point Lon, thanks for adding your 2 cents to the pot. I completely agree that this can pose a security risk.
