Google Analytics code messes up site
Thread begun 11/03/2010 1:31 pm by elevy388997 | Last modified 7/10/2013 12:36 pm by doug425125 | 4414 views | 6 replies |
elevy388997Beta Tester
Hello,
When I add the include_once code for google analytics tracking on a php page, it messes up my site. The formatting has to be off. It says to place this code after the <body> tag:
<?php include_once("analyticstracking.php") ?>
Whatever content was on my page gets replaced with this text:
Untitled Document </head>
sounds like there is an error in the analyticstracking.php file.
add the code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
This is the code on the analyticstracking.php:
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
var _gaq = _gaq || [];
_gaq.push(['_setAccount', 'UA-17837578-1']);
_gaq.push(['_setDomainName', '.levy4u.com']);
_gaq.push(['_trackPageview']);
(function() {
var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
</script>
</head>
<body>
</body>
</html>
try changing the code to just the script tag:
(function() {
</script>
doug425125
Hi Jason
I was having the same problem. I placed the <?php include_once("analyticstracking.php") ?> code just before the </body> tag, and I was able to see and edit my Dreamweaver .php files. I'm not sure if this is the best place to put the code for tracking purposes? Is it acceptable to do this?
When you were referring to changing the code in your last response, were you suggesting removing everything except the script tag and contents? ( just for my clarification.. thanks
Doug
Originally Said By: doug425125
  Hi Jason
Doug
doug425125
Thanks for clarifying Jason.. I removed all but the script, and kept it just after the body tag.. and it works perfectly. I understand now that it would have duplicated that various tags and become invalid HTML. I Appreciate the explanation.
Cheers,
Doug
