Errors on installation of CSS Form Builder 2
Thread begun 10/25/2010 10:43 am by gary917 | Last modified 10/26/2010 6:37 am by Jason Byrnes | 4854 views | 9 replies |
gary917
I am getting all kinds of error messages when installing Form Builder 2 into Dreaweaver CS5.
The first error states that I have installed CSS Form Builder while still having Digital File Pro, Universal Email Pro, HTML Editor, and Validation Toolkit. Please close Dreaweaver, uninstall Digital File Pro, Universal Email Pro, HTML Editor, and Validation Toolkit the then re-install Form Builder before re-starting Dreaweaver. You may experience issues if these steps are not taken.
Ignoring this message creates all kinds of errors when Dreamweaver is opened.
Do I have to uninstall Digital File Pro, Universal Email Pro, HTML Editor, and Validation Toolkit then install Form Builder 2 and then re-install Digital File Pro, Universal Email Pro, HTML Editor, and Validation Toolkit?
CSS Form Builder 2 contains all of the functionality of Validation Toolkit, Universal Email, Digital File Pro and HTMLEditor.
You need to uninstall Digital File Pro, Universal Email Pro, HTML Editor, and Validation Toolkit then install Form Builder 2.
by installing CSS Form Buuilder, you will be reinstalling the functionality of the other extensions.
cgreen1167375578
HTML Editor
I see no program from Web Assist to remove with this name! What is the name of the HTML Editor to remove?
HTMLEditor is the new version of iRite.
you will need to uninstall iRite before installing CSS Form Builder.
gary917
More Errors
I have did as you suggested and disabled the following...
This solved the that problem but now I am receiving another error.
When I go to alter or add a "Clear Session Values" I receive the following error.
While executing onLoad in WACT_ClearSission.htm the following JavaScript error(s) occurred:
Line 357 of "C://Documents and Settings-----------------WebAssist/Cookies/Library/WA_Configuration.js". getTagProp is not defined.
I have tried deactivating and deleting the Cookie Toolkit without success. I have also tried to reinstall CSS Form Builder 2 also without success. As well I have tried clearing the Dreamweaver's cache but the problem remains.
this is an issue that will happen using the clear session value behavior when security assist is enabled.
Please disable security assist in the extension manager before using the clear session value behavior. We will be releasing an update soon to correct the issue.
gary917
RE: Error
Thanks will be looking forward to the fix.
you're welcome.
info147418
Problems after installing Form Builder
Dear Webassist Team.
Thank you very much for making many good products.
I have installed different extentions from your Suit packet. After installation of Form Builder I also have received different errors. After that I uninstalled all extentions and try only to install Form Builder. I received an error as seen as the first error on the attached pdf file.
Then I try to install some of the other extentions again, but receive another error: The following tranlators wer not loaded du to errors: WAFV_Display.btm: has configuration information that is invalid.
I include a screen shot of the installed extentions.
After installing all the extentions, I have tried to uninstall and install Form Builder again, but with the same orror.
I hope that you very soon can send me some good information, so I can solve the problems and start working againg.
Thank you very much.
Best regards
John
Try resetting the workspace layout, go to Window -> Workspace Layout -> Reset '<Your Layout Name>'
then delete the Dreamweaver cache file from the users configuration folder:
