Nesting DataAssist Repeat Selection
Thread begun 6/14/2009 10:54 am by Bknvc1111729 | Last modified 6/15/2009 7:30 am by Ray Borduin | 1609 views | 1 replies |
Bknvc1111729
Okay, I have been working on this issue for a couple of days now and I am not sure if I am doing something wrong or if DataAssist Repeat Selection can handle this.
Basically I want to have a portion of my form repeated so I only have to enter the basic product info once and the option fileds repeated say five times. I can get this working no problem.
Problem is when I try to get the Bolt Pattern checkbox to repeat through the table that holds the data for that section to display in more than the first repeated selection. All the repeated fields will show except the nested repeat selection for the checkboxesin the repeated lines 2, 3, 4, and 5.
Can DataAssist Repeat Selection handle a nested DataAssist Repeat Selection? Or is there some coding I need to do by hand to get this to work?
Bknvc1
On line 327, try adding:
mysql_data_seek($rsPatterns, 0);
$row_rsPatterns = mysql_fetch_assoc($rsPatterns);
I think the problem is that it doesn't go back to the first record automatically after the loop and since you have one loop nested inside the other it needs to reset after the nested loop completes.
