Roll Over Data
Thread begun 10/14/2010 8:19 am by john411474 | Last modified 10/27/2010 2:12 pm by Dani Chankhour | 2398 views | 5 replies |
john411474
Roll Over Data
Is it possible to add another field value to the "roll over"
When using "show multiple data sets" would like to add "size"
to the current chart showing store and price see attached jpg
Also can the roll over value (price) be formated to x.xx
thanks
jrt
Dani Chankhour
yes, you can add the size to the point. However that is going to require some custom coding and if you reenter Dynamic Web Charts then those changes will be removed.
In the Dynamic Web Charts folder under the Data folder can you send me the page that ends with _data1.php and start with your file name.
john411474
Roll Over
Attached is the data1.php file saved as .txt
Please provide "remarks" around the the cost field addition
Would like the average price to be 2 decimal points also
thanks
jrt
Dani Chankhour
Try changing this line of code:
<label><?php echo($row_WADWC_data['XLABEL']); ?></label>
to
<label><?php echo($row_WADWC_data['XLABEL'].$row_WADWC_data['DATAGROUP']); ?></label>
to format the price
change the line under to:
<value><?php echo(number_format($row_WADWC_data['YVALUE'], 2)); ?></value>
john411474
Roll Over
Thank you for the quick reply
<label><?php echo($row_WADWC_data['XLABEL'].".\n".$row_WADWC_data['DATAGROUP']); ?></label>
added ".\n". for line break
This put's size in roll over but also put's in x axis, which is ok until there are more than 5-6 data points.
however
to format the price
<value><?php echo(number_format($row_WADWC_data['YVALUE'], 2)); ?></value>"
this does not appear to work
see attached screen print
thanks again
jrt
Dani Chankhour
It looks like this is a limitation of how the flash displays the value. It only displays an integer but not a float.
