Problem with changing Mail type
Thread begun 6/13/2009 6:51 am by rmleczynski311091 | Last modified 6/15/2009 7:00 am by Ray Borduin | 1905 views | 1 replies |
rmleczynski311091
I am having a problem with changing the mail type on the email password page in SA 1.1.7 wizard. If I enter all the info at the top of the page, from address - display name- subject, and then change the email object from mail for windows to mail for linux, it deletes the info at the top and if I reenter it, and click finish it generates an error and tells me that it needs the from address. Is this a problem with something I am doing or a glitch in SA?
I'm not sure. It may be a glitch that you need to set the email object first and it clears the fields when updated.
If you enter the from address and then put focus into another field in the interface can you finish the wizard and everything still works?
Please post a support incident. That will allow someone to work to reproduce and debug this issue with you.
