CSS Menu Writer wizard stops displaying
Thread begun 6/11/2009 3:07 pm by Ozdachs | Last modified 6/11/2009 5:11 pm by Ozdachs | 2108 views | 2 replies |
Ozdachs
After using the CSS Menu Writer wizard for a while, the panels stop displaying the parameter information or previews. I can go from tab to tab within the wizard, but NO information (not my customizations nor the defaults) display. (See attachment for example.)
Is there something I am doing wrong? I have tried this three times now, losing all of my changes each time.
BTW, I see the same non-display behavior when I customize CSS Sculptor. But, that program at least goes back to a automatically saved version of my changes.
We have tracked down this issue as a memory leak in dreamweaver associated with changing the visibility of layers.
We believe we will be able to solve the problem in the next release, but unfortunately there is little we can do in terms of a work around until that update is available.
I will log a bug that the settings are not being automatically saved as well. Thank you for reporting this issue.
Ozdachs
Thanks... at least it isn't me! (or you!)
