authorize.net (linkpoint) going live
Thread begun 9/28/2010 10:29 pm by CraigR | Last modified 9/30/2010 3:33 pm by Jason Byrnes | 5991 views | 16 replies |
CraigRBeta Tester
linkpoint going live
I have a client with PS3 who is struggling to go live.
He has attempted to get linkpoint (first data) working, but always gets a transaction failure.
he has the pem file in the linkpoint folder on the root and set the global settings to use gateway 2 as there is no option for linkpoint, 2 sets the gateway to be authorize.net
from what i understand, if the gateway is set to 0, (no gateway), then the C/C form is not displayed
there is an eCart local checkout server behavior on the confirm.php page with. it seems, all relevant details.
i have pasted the appropriate checkout response bindings into checkout_failure, but when i check local checkout response errors, i get nothing.
SO, i added Full Request and Full response to my checkout failure page, get a load of text, which implies the transaction is good, but i get transaction failure.
can someone please walk me through what to check.
(i also just noticed that in the wa_settings table, there is no data for login or transaction key for gateway 2 (lines 34 & 35), which i assume is for authorize.net only so assume this isn't a factor ?)
here is my binding, (edited) and presented in an easy to read format..
<order>
<merchantinfo>
<configfile>0000000000</configfile>
<keyfile></keyfile>
<host>https://secure.linkpt.net/lpcentral/servlet/lppay</host>
<port>1129</port>
</merchantinfo>
<orderoptions>
<ordertype>SALE</ordertype>
<result>GOOD</result>
</orderoptions>
<payment>
<tax>0</tax>
<shipping>7.95</shipping>
<subtotal>4.99</subtotal>
<chargetotal>12.94</chargetotal>
</payment>
<billing>
<name>Name</name>
<address1>Address1</address1>
<address2>Address2</address2>
<city>City</city>
<state>N/A</state>
<zip>ZIP</zip>
<country>GB</country>
<phone>12345 67890</phone>
<fax></fax>
<email>mail@mail.com</email>
</billing>
<creditcard>
<cardnumber>1111111111111111</cardnumber>
<cardexpmonth>12</cardexpmonth>
<cardexpyear>2011</cardexpyear>
<cvmvalue>765</cvmvalue>
</creditcard>
<shipping>
<name>Name</name>
<city>City</city>
<state>N/A</state>
<zip>ZIP</zip>
<items>1</items>
<weight>0.1</weight>
<total>4.99</total>
</shipping>
<transactiondetails>
<taxexempt>N</taxexempt>
<terminaltype>UNSPECIFIED</terminaltype>
<oid>q3vnqq639205hutfleiegjelo7</oid>
</transactiondetails>
<items>
<item>
<id>73</id>
<description>Product Description</description>
<price>4.99</price>
<quantity>1</quantity>
</item>
</items>
</order>
thanks
the heart of the issue is that it is not finding the key file:
<keyfile></keyfile>
the code to find the key file will look similar to:
$LinkPointAPI_required[0][$nextIndex] = "merchantinfo->keyfile";
  $LinkPointAPI_required[1][$nextIndex] = "".realpath("../linkpoint/test.pem")  ."";
the real path command should return a OS path to the file similar to:
/Applications/MAMP/htdocs/linkpoint/test.pem
in some cases, i have seen issue if the path contains /n or /t being interpreted as a new line or tab
So it may see:
/test.pem
and interpret that as "{tab}est.pem" (i put tab in {} for demonstration sake.)
if this is the case, you can get around the issue by hard coding the path to the pem file:
  $LinkPointAPI_required[1][$nextIndex] = "/Applications/MAMP/htdocs/linkpoint/test.pem";
CraigRBeta Tester
Hmm.
well the pem file is definitely there, and the path is as you suggested it would be.
i don't want to hardcode it, as it won't work when the files move from the testing server.
i tried echoing the line on the checkout page like so...
echo 'path is'."".realpath("../linkpoint/number.pem") ."";
but it returns nothing.
do i need to use realpath at all or can i use a relative path ?
it has to be the full OS path, not a relative path.
where is the pem file located in relation to the confirm page?
your code:
is moving down one directory from the confirm page to look for the linkpoint folder. is this correct?
what if you use:
<?php echo("Confirm Path: ".realpath("confirm.php").""); ?>
what does that return?
CraigRBeta Tester
thanks Jason, little light bulb suggests path was keyed in looking at an example, and the pem file is in the linkpoint folder in the root, same as the confirm page.
So, now the pem file is being retrieved correctly, the transaction still fails, but the <keyfile></keyfile> tags now contain a value, which is the correct path to the pem file.
**Just a thought, this is my clients pem, will it actually work on my testing site ??**
it should work from your testing site.
do you still not get any full response back? still only the full request?
CraigRBeta Tester
no response at all, just the request
CraigRBeta Tester
Thanks Jason.. 99% there
Many thanks for the call yesterday Jason.
Just to confirm the changes made if anyone else wishes to go along the linkpoint route, (don't)..
Ensure the .pen file path is correct
Change the url to $LinkPointAPI_required[1][$nextIndex] = "secure.linkpt.net";
set the expiry year for c/c to 2 digits instead of 4, and alter the validations accordingly
ensure the trigger to populate the linkpoint array is on the 'submit order' button being pressed, and NOT any form post.
Now here's the problem I still have.
I uploaded the files to my testing server, and everything works perfectly, as it did last night.;)
I then uploaded the same files to my client's server, and I get transaction failed again.
It seems to take a very long time to decide not to connect, so it may well be a timeout issue ??
(If i put in a url that i know is incorrect, it fails pretty much instantly)
I know this doesn't make sense, but there you are.
I consulted the linkpoint manual, and the url it provides is different, so I also tried this and some variations, but no success.
I added the local checkout response codes to checkout_failure, and again, the full request is shown, but no response.
( i get the error, regardless of whether the site is in 'test' mode), as defined in the first tab of the admin settings page
I am struggling for ideas
johnb
Subscribing... Interested in the outcome of this
