Security Assist Bug?
Thread begun 9/27/2010 9:15 pm by twitchr377598 | Last modified 10/07/2010 7:55 am by Jason Byrnes | 5185 views | 8 replies |
twitchr377598
Hello Webassist gurus,
I used security assist to add a registration and log in page to my site. I am wanting to add a session variable to my existing authenticate user server behavior. I open up the authentic user behavior in the wizard and page over to step 3 where you can add or delete session variables. I click the plus button and a list of my columns shows up in a menu, I choose one and nothing happens. It doesn't let me add a session variable here. Any thoughts?
I'm using CS5 and Security Assist version 1.1.9.
In the meantime, where do I add a new session variable in the code by hand? I currently have a session called memberID from the memberID column in my members table. I want to make a session called memberStatus from the memberStatus column in my members table upon log in as well.
if(isset($_POST["LogIn"])){
$WA_Auth_Parameter = array(
"connection" => $mydatabase,
"database" => $database_mydatabase,
"tableName" => "members",
"columns" => explode($WA_Auth_Separator,"memberEmail".$WA_Auth_Separator."memberPassword"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".WA_SHA1Encryption(((isset($_POST["userpassword"]))?$_POST["userpassword"]:"")) .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"memberID"),
"sessionNames" => explode($WA_Auth_Separator,"memberID"),
"successRedirect" => "index.php",
"failRedirect" => "email_pw.php",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
Thanks in advance,
Twitch
I'm trying to reproduce the problem, but am not able to. The Selected column is being added to the session variables list.
perhaps try deleting the Dreamweaver cache file from the users configuration folder:
in the mean time, you can manually edit the code.
change:
to:
"sessionColumns" => explode($WA_Auth_Separator,"memberID".$WA_Auth_Separator."memberStatus"),
"sessionNames" => explode($WA_Auth_Separator,"memberID".$WA_Auth_Separator."memberStatus"),
twitchr377598
Thanks for the quick reply, Jason. I was using $WA_Auth_Separator, instead of .$WA_Auth_Separator. when editing by hand. I'll give that a try shortly. As for the bug, I may end up wiping my machine and starting from scratch. I've had various other issues. Maybe it's not the extension. I'll keep you posted. I've just had too much work to have my computer down for any length of time to redo it...haha A good problem to have I guess.
Thanks again,
Twitch
instead of reinstalling the entire system, you may want to try deleting the configuration folder and reinstalling the extensions.
The common installation issues technote will help you locate the configuration folder.
Close Dreamweaver and the Extension manager, then you can delete the configuration folder and re open the extension manager. This will disable all of the extensions. from here, you should uninstall each one, then download the latest mxp files and reinstall them.
twitchr377598
Thanks Jason, I know the configuration folder well unfortunately...haha That said, editing manually did the trick.
While on the subject of logging in, is there a way to have an authenticate user behavior look at 2 different tables for logging in, ie: verify the username and password exists from either a table called 'users' or table called 'admin'?
Did a quick search of this forum but didn't see anything similar.
Thanks in advance!
No, not really.
The closest would be to have two authenticate user behaviors on the page, one for each users table.
You would also need to have separate login forms.
you would be better combining users and admins into one table and using User Level Authentication.
The solution recipes section of the Security Assist support page talks about this.
Steve
I have the same problem...
Happens on the second page as well. When you try to add a field it does nothing. Click try again, again, again etc etc eventually it works. But it only works for adding one field.. Close and open try again and again then eventually you'll get to add your second column (such as password). Then off to page three... Same problem, select to add, chose an available value to use as a session then it never completes...
CS5 latest stuff, 10 gigs of Ram, etc etc.. Yes' I'll now try removing the dat file
Steve
Removed dat files and even restarted the putter..
Got one session value to take now back to being useless. No new values will "take'....
very disappointing.
This stuff only tested on a PC?
You have an open support incident for another issue, we will look into this issue with you on the phone at the same time as the other.
