Validation Toolkit producing bad code
Thread begun 9/24/2010 10:49 am by cj381970 | Last modified 9/28/2010 3:10 pm by Jason Byrnes | 3755 views | 10 replies |
cj381970
Dear Support,
It seems that my validation toolkit is not funtioning properly. I have deleted my config library and un/re-installed the component multiple times and am still receiving the same results. When I run the Client Validation Wizard on my checkout.php page the code that is produced is the following:
<form action="confirm.php" method="post" name="ecart_checkout_form" onsubmit="WAValidateCC(document.forms[1].cc_number,document.forms[1].cc_number.value,'- Invalid credit card number','','4:51:52:53:54:55:34:37:6011:',document.forms[1].cc_number,0,true);WAValidateRQ(document.forms[1].cc_number,'- CVV is required',document.forms[1].cc_number,0,true,'text');WAValidateRQ(document.forms[1].cc_number,'- Fisrt name is required',document.forms[1].cc_number,0,false,'text');WAValidateRQ(document.forms[1].cc_number,'- Last name is required',document.forms[1].cc_number,0,false,'text');WAValidateEM(document.forms[1].cc_number,document.forms[1].cc_number.value,'- Invalid email address',document.forms[1].cc_number,0,true);WAValidatePN(document.forms[1].cc_number,'- Invalid phone number',false,true,'',document.forms[1].cc_number,0,true);WAValidateRQ(document.forms[1].cc_number,'- Address is required',document.forms[1].cc_number,0,false,'text');WAValidateRQ(document.forms[1].cc_number,'- City is required',document.forms[1].cc_number,0,false,'text');WAValidateZC(document.forms[1].cc_number,'- Invalid zip code',true,true,true,true,'',document.forms[1].cc_number,0,true);WAValidateRQ(document.forms[1].cc_number,'- Shipping name is required',document.forms[1].cc_number,0,false,'text');WAValidateRQ(document.forms[1].cc_number,'- Shipping name is required',document.forms[1].cc_number,0,false,'text');WAValidatePN(document.forms[1].cc_number,'- Invalid shipping phone number',false,true,'',document.forms[1].cc_number,0,true);WAValidateRQ(document.forms[1].cc_number,'- Shipping address is required',document.forms[1].cc_number,0,false,'text');WAValidateRQ(document.forms[1].cc_number,'- Shipping address is required',document.forms[1].cc_number,0,false,'text');WAValidateZC(document.forms[1].cc_number,'- Invalid shipping zip code',true,true,true,true,'',document.forms[1].cc_number,0,true);WAAlertErrors('Correct invalid entries to continue','',true,false,false);return document.MM_returnValue">
As you can see cc_number is repeated in every validation as opposed to the proper object names so I have to manually change each to the correct name for the form to validate. This solves the problem until the City (select list) gets validated. The validation will not accept a selected value and continue. Please advise.
Your help here is greatly appreciated,
CJ
When you start the client validation wizard, make sure that the correct form is selected in the dropdown list, then go thorough and reapply each validation.
cj381970
peoled pointed
There are only two forms on the page, form[0] is the paypal express checkout form, form[1] is the correct form. I've reapplied each validation multiple times and have gotten the same result.
What version of validation toolkit?
can you send a copy of your page.
cj381970
attached, thanks.
you didn't answer my question:
cj381970
version 2.3.5
I am not able to reproduce this issue.
What is your OS?
What version of Dreamweaver are you using?
cj381970
Mac OSX 10.6.4
CS4
cj381970
Any suggestions here? This extension is not working correctly.
