More info on Managing Relational Tables
Thread begun 6/11/2009 8:06 am by Bknvc1111729 | Last modified 6/12/2009 7:46 am by Bknvc1111729 | 3807 views | 6 replies |
Bknvc1111729
Where would I look to find more info or solutions explaining DataAssists feature for managing relational tables?
Bknvc1
Neil Beadle
This is definitely the most complicated function of DataAssist. At this point in time, the only documentation we have regarding this aspect is within the built-in help documentation. We do hope to produce some intermediate database tutorials to aid users in understanding of how this feature would be implemented.
If you have trouble getting it to work, submit a support ticket so that a support engineer can point you in the right direction.
Bknvc1111729
Still having an issue getting the Manage Relational Tables to work. Maybe it is not designed to work like I think it is but here is what I am trying to do. Maybe someone here can point me in the right direction.
I am inserting a product into the database with one form. There are the fields for the the main product information then there are the fields for the product options. In the options there is a checkbox that is using the Repeat Selection behavior to be displayed.
I have inserted an Insert Single Record behavior for the fields that describe the basic product and have them written to one table. This is working okay.
I have an Insert Multiple Records behavior for the remaining fields because they could choose more than one checkbox and for each checkbox checked it would write a new record to a second table. This is also working fine.
When I add the Manage Relational Table behavior is where I am having an issue. I want it to write to the third table the Key columns of the other two tables so I can associate the product with its options. I can not get this to write to the third table.
Support told me to remove the redirect from both Single and Multiple Insert Records. When I tried I get the same results as above.
Does anyone here have any suggestions?
Bknvc1
It won't work like that by default. The issue will be that you can't identify the newly inserted IDs from the insert multiple record to properly create the relational table reference.
I'm afraid you would probably have to hand code this solution.
Manage relational tables would work in a scenario where you had the multiple records listed with a group of checkboxes or multilselect list and were able to bind the values to the associated table IDs. Since in this case the ID's don't exist until after the insert, it really just won't work without editing it by hand and maybe storing an array as you insert of the ID's and then referencing that array in the manage relational table code in place of the form element it would normally work with.
The code concepts and code would be very similar, but it would take a little editing by hand to really pull off since it isn't directly supported in the interfaces.
Bknvc1111729
Okay, sounds a bit over my head at this point but if I that is what I have to do I will figure it out.
But before that do you think this would work. Have a page that inserts the basic product information and then have another page that they select the basic product and then add the options required for that product. Could I then get the Manage Relational Table behavior to reconize the basic product's key and insert it into the relational table along with the option's key column as it is generated? Or is the issue that scince niether key column is known at the time of insertion that the data is not written to the relational table.
Just trying to understand.
If you think of manage relational table as helping in a Parent - Relationship - Child database scenario... the Child Fields have to exist and be used to populate a list or checkbox group on the page in order to update the Relationship table properly. You can insert the Parent and manage the Relationship on one page, but you can't also insert into the child since the child has to be used to populate a list or checkbox group for manage relational database to work.
The child table fields have to already exist.
Bknvc1111729
Okay, now I think I understand. Thank you for your patience and input.
Bknvc1
