need help for ecart???
Thread begun 3/12/2009 12:14 pm by toleehua356796 | Last modified 3/12/2009 3:13 pm by Ray Borduin | 4260 views | 3 replies |
toleehua356796
i rebuilder mine website. used the ecart. follow the {eCart 4
Getting Started Guide} build all the page. eg: items_Results.php page. when i finish the all page. used the fire fox . only show me this: Parse error: syntax error, unexpected T_VARIABLE in C:\AppServ\www\yaozone\WA_eCart\BlueSkyCart_PHP.php on line 10
when i open the code :
//WA eCart Include
require_once("WA_eCart/BlueSkyCart_PHP.php");
?><?php require_once('Connections/connbulesky.php'); ?>
$BlueSkyCart->GetContent();
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "") *******wrong on this line 10 ******
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
i don,t know how to fix this. can any one can help?
Thanks ! I am new. please toll me how to fix it. i need step by step to fix. please?
CraigRBeta Tester
wrong code posted ?
if i read this correctly, the error is on the page below, not on the page you posted
"\BlueSkyCart_PHP.ph p on line 10"
Art
Originally Said By: CraigR
I would guess the person is looking for the error in the actual page not the
cart folder page.
Look at line 10 of the file: WA_eCart\BlueSkyCart_PHP.php
that is where the issue is happening.
