Dreamweaver CS5 - compatible with WA extensions?
Thread begun 9/16/2010 11:54 am by nibo | Last modified 9/16/2010 12:29 pm by Jason Byrnes | 1243 views | 2 replies |
nibo
I've just installed all my WA extensions into Dreamweaver CS5 and after having trouble with opening Universal Email 3.0.7 I looked up this forum for help on the issue. I then discovered that 3.0.7 won't work on CS5. I can't even upgrade to a new version as I'm using ASP.
Could anyone tell me or point me to somewhere where I can find out if there are other extensions that won't work with CS5?
I will be gutted and very annoyed if I can no longer use the extensions I've paid for. How can I work on and edit sites that I've previously created using all of the WA extensions?!?!?!
Unfortunately you'll have to keep using cs4 and earlier versions of our extensions in order to continue with Classic ASP. We announced dropping ASP classic more than a year ago now. You can still use the extensions, you just have to use the old version of the extension on the old version of DW that they supported, in this case CS4.
Eventually all of our extensions will stop working for Classic ASP and Coldfusion, and we won't support newer versions of Dreamweaver for those extensions after that point. Really you'll have to stop upgrading webassist extensions for anything other than dot releases since full version updates will drop Classic ASP.
The latest versions of Our extensions have been updated to be compatible with Dreameaver CS5.
As long as you have the most recent versions, for example Universal Email 4 or eCart 5 they will be compatible with CS5.
