Google Maps and Spry
Thread begun 6/09/2009 10:22 pm by steve56638 | Last modified 7/03/2009 11:04 pm by meister281653 | 7014 views | 6 replies |
steve56638
I love the Google Map extension however I would like to use it within a tabbed spry element... on the second panel... however this is were the problems start.
If I display the google map with the initially opened tab it works fine... however if I display the map on the second tab... the marker is not centered and is actually off the map... how can I show a Google map on the second tab of a spry element...
I also need to make sure the info window remains visable once the icon is clicked...
Help... and thanks
Steve
This isn't directly supported, but I imagine you could write client side javascript code to readjust the info window and center of the map associated with the spry tab change.
If you provide a url I can take a look and see if I can be more specific.
Martin
Hi Ray,
I am also having this issue with my Map centering of the page.
contact.php#1_3. - the Google Map Tab
I am also using a tab panel script as well.
If you go to the top of the page, you will see another map link, but it work perfectly.
I have not a clue what script needs to be written to ensure it centers.
thanks for any help!
Martin
nathan125991
various sources
I have read from various sources that the Google Map API and spry are incompatible. The only way I know how to work around this is to place your element in an iframe. The solution is quite ugly, but it's the only known workaround.
Use jquery and Googlemaps. It took me 8 hours of debugging, research, and tears the last time I had to do something like what you're describing.
meister281653
Isnt it possible, to say, the TAB where the map is is default. and with an onload you do a virtual click on the first TAB.
so the tab with the google map is default, centers right, and wit the onload you switch directly to an other tab.
does that work?
meister281653
this is nearly nice, but not right centered :-)
<script type="text/javascript" src="google_javascript/wagmp_maps.js">/*wagmp*/</script>
var TabbedPanels1 = new Spry.Widget.TabbedPanels("TabbedPanels1", {defaultTab:1});
window.onload = function(){ TabbedPanels1.showPanel(0); };
</script>
someone from the google forum toold, that I have to insert a new size in the webassist created php file.
var map = new GMap2(document.getElementById('wagmp_map_1'),{size:new GSize(300,300)});
but it is not really centered :-(
meister281653
can someone tell me how to use the Map in spry if its not default?
Please,
Denis
