multiple user folders in html editor
Thread begun 9/09/2010 1:42 pm by alex407656 | Last modified 9/13/2010 4:07 am by Willi Schneider | 2521 views | 2 replies |
alex407656
Hi i have installed html editor and everything is working great
however
I wish to integrate it with a user management system (not security assist) so each user has their own folder to upload to (images/business/12jbJ86CH8391n2lu4bi1if9H2/) however the editor system just has one user folder which defeats the entire purpose of the system.
I tried using sessions to change the folder however this just creates errors. (it uses database tables)
any ideas?
Thank you in advance
no, it's not possible to have unique users folders for the image upload in HTML editor.
Willi Schneider
Solution using session variables
Hi Alex
I'm using the following solution for PHP:
1. Configure your upload folder settings in the HTMLEditor user interface like this:
/images/business/'.$_SESSION["your_session_variable_name"].'/
You could even append several variables for more sophisticated security settings:
/images/business/'.$_SESSION["your_session_variable_name"].'/'.$_SESSION["your_second_session_variable_name"].'/
Just make sure you are using the above syntax.
2. Add this line:<?php session_start(); ?> on top of the following pages:
i: --> Your HTMLEditor form page
ii: --> /HTMLEditor/editor/filemanager/connectors/php/config.php
iii: --> /HTMLEditor/editor/plugins/kfm/configurtion.php
Make sure, you backup these files for your own safety, before you make any changes...
The settings get stored in the HTMLEditor GUI, so I can use them for all my forms.
Of course the user must be logged in properly.
HTH
Willi
