Intermittent problem adding a new recordset in CS4
Thread begun 3/12/2009 10:19 am by CraigR | Last modified 3/24/2009 2:52 pm by CraigR | 4123 views | 4 replies |
CraigRBeta Tester
This problem occurs only sometimes, but it is certainly an issue.
I have tried deleting the cache file and restarting but this doesn't necessarily work
i have tried disabling some extensions, but no luck so far.
This has only been an issue since CS4
This appears to be an issue with many of our server behaviors in cs4. We have discovered a fix and we are working to update our products that exhibit this problem.
If you create a support incident, they have a temporary solution that may work for you.
CraigRBeta Tester
Thanks Ray, I've done that
anonymous
hummmmm..... I keep getting the same intermittent problem. I've had a support request in since the 21st. Seems like the aren't aware that they are supposed to have a temporary fix. Any ideas what it would be? I've tired the cache, no help. I was able to make a completely different site and get it working again but today.......it's back.
CraigRBeta Tester
fix
i got a reply within 24 hours with a patch to fix my ecart.
i haven't had the problem since.
update your ticket with a kindly reminder.
if no luck, post again and I will upload the fix they sent to me.
