large insert to edit area overwrites next field and corrupts list of editable fields
Thread begun 6/09/2009 11:49 am by peter348932 | Last modified 6/11/2009 3:20 am by peter348932 | 5173 views | 6 replies |
peter348932
background: each page on this site has 2 fields that the client can update.
I've just handed over the site to a client to "practise" updating the site - the first thing they did was cut and paste their multi-page cv into the first field and saved it - the result was the page engulfed the second field, the contents of the second field is now attached to the end of the first field and where the second field should be is empty. at the same time when you go back into admin and look at the pages to edit ,all pages and fields AFTER this corrupt page are missing. if I delete this page the database corrects itself, but if I cut and paste a multipage document into a field is truncates and means to destroy the other fields on that page as well as making the other pages after this field unreachable.
its seems to be a limit on the size of the text, (my client would like their Cv on a scrolling page)
are there any error checks to stop data over writing other fields?
see - biography.php the bad one - this is what is used to look like with a small amount of text: background.php
thanks
(I have raised this in support)
I'm afraid I don't really understand the question or what is happenning that you don't expect. Maybe you can try to describe it a different way or include more details... I'm just not getting it.
Hopefully someone in support might understand your question and problem.
peter348932
cms corrupt when pasting several pages.
ok - on a page I have 2 regions :
<?php echo WA_getCMSContent($database_localhost, $localhost,"biography", "quote"); ?>
<?php echo WA_getCMSContent($database_localhost, $localhost,"biography", "main"); ?>
see background.php as an example that works it displays the quote and the main content.
when I go into power cms admin and look at "available site pages" I have 15 odd pages in alphabetical order that I can edit and have similar lines of code in their respective pages.
When I edit the biography site page, I paste a CV (word) document of several pages into the biography main section, and then save and go and look at the result, the main area is truncated and the second area disappears. then when I go back into the admin all the lists of site pages past the page I pasted the CV into have gone and I'm unable to re-edit them.
the duffpage page is: biography.php
I see. I was originally looking at the page in FireFox, which seems to keep the quote in the correct spot.
Please give me a call at the webassist main line ext. 103.
I would like to look into this further with you directly.
peter348932
I'll give you a call - I've just tried the admin in FF and it does edit ok. and also in Safari
but in IE6,7 and 8 nothing is displayed after Biography in the admin.
It looks like you tried to contact me sometime after 8pm my time yesterday. If you could try calling now or sometime in the next 9 hours I should be available.
peter348932
cutting a page at a time corrects this
Hi Ray thanks for your time yesterday. Cutting and Pasting directly is not advisable and to always use the "paste from word" button and tick the cleanup boxes really helped.
the last problem-ette - If I cut and paste the whole word document into the edit area something goes wrong with the display, however cutting&pasting a page at a time into the same area and appending it seems to get over this problem. I suspect its a microsnot's office problem.
anyway - I have a fix thanks again foryour help
