Universal Email 4 Does not sent fields of the record set.
Thread begun 8/31/2010 8:13 pm by ingsercon21251 | Last modified 1/21/2011 7:39 am by Jason Byrnes | 6540 views | 13 replies |
ingsercon21251
Hello
I used to work with UE3 sending emails using a record set loop and I could add more fields of the record set into the email body.
Now I am using UE4, but I can not see the way to do exactly the same thing.
I just need to put my customer full name and the business name into the email body.
Actually the email is sent but the only appear with the name an business name of my first customer in the record set loop.
Any Idea what i need to do ?
roby258376
I am having the exact same issue. A solution here would probably be helpful. Or should I open a support ticket as well?
can you send a copy of the page that universal email is applied to and the webassist/email folder in a zip archive so i can examine the code please.
roby258376
Files are attached, please let me know if you need anything else.
try changing the recordset call in the mail/waue_massMail1.php file to use this syntax:
$RecipArray[$CurIndex][]
instead of :
$row_rsEmails
for example, change:
$MailBody = $MailBody .  $row_rsEmails['memberFirstName'];
to:
$MailBody = $MailBody .  $RecipArray[$CurIndex][]['memberFirstName'];
roby258376
With that change, the emails are no longer being sent and the redirect after hitting submit no longer works either.
my apologies, it should be $RecipArray[$RecipIndex][0]:
try this example:
$MailBody = $MailBody .  $RecipArray[$RecipIndex][0]['memberFirstName'];
roby258376
Hi Jason,
That new code finishes with a redirect, but the emails still all show the first records information.
make sure you are changing all three lines that use the recordset code:
$MailBody = $MailBody . $row_rsEmails['memberEmail'];
$MailBody = $MailBody . $row_rsEmails['memberPassword'];
anywhere that is using a recpordset reference in the email needs to have "$row_rsEmails" changed to "$RecipArray[$RecipIndex][0]"
