Error on opening Dreamweaver CS5
Thread begun 8/24/2010 11:12 pm by htm2112 | Last modified 10/10/2013 6:23 am by Jason Byrnes | 7175 views | 5 replies |
htm2112
I installed Dreamweaver CS5 and I have an error when I open it: "Unable to find file BL.htm in the Configuration/Floaters directory. The floater will not be shown." Of course, I could uninstall all my extensions and re-install them, but that takes a lot of time. Some extensions can take 10 minutes to uninstall or install. Given that I have all the extensions from the WebAssist library (which I just converted to the Super Suite, since the subscription is being discontinued), I don't want to re-install all of them. Any idea which extension could be causing this error?
I just click OK and I have no problems in Dreamweaver, but I have no idea what is not being loaded.
not sure what the BL.htm file is for, but I don't believe it is something to do with our extensions.
do you have other extensions installed from other companies?
for the error, go to window -> Workspace layouts -> Reset '<Your Layout Name>'
htm2112
Thanks. Reseting the layout fixed that problem.
Excellent, glad to hear it is working.
michaelf0199272
WebAssit extension is causing error when launching Dreamweaver CS5
Go to WebAssist -> Preferences in the Memento section Set the Show in dreamweaver option to Never.
In the RSS Section, check the option to disable all RSS Feeds and Check For Updates only when Memento opens.
Then go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
http://www.webassist.com/tutorials/Common-installation-issues
