Content not displaying
Thread begun 6/08/2009 10:21 am by info381123 | Last modified 6/08/2009 12:40 pm by info381123 | 3491 views | 4 replies |
info381123
I`m getting no content display, error messages include:
Notice: Undefined variable: database_localhost in /****************** on line 41
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /*************l/WA_CMS.php on line 3
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /*************l/WA_CMS.php on line 5
* instead of the URL
Hoping someone can help as I`m a bit fed up waiting for support tickets to answered properly.
It sounds like your database connection is not referenced properly. Look at the file in connections/localhost.php and make sure your database is referenced properly.
info381123
Thank you. I corrected that file and now it displays OK.
Still get a couple of error messages if I leave reporting on but it does now work, should I worry about it?
What are the error messages? I would probably correct them.
info381123
I found some spurious code at the bottom of the page, cleaned it up all errors now gone.
Thanks again.
