How to change color of menu bar to reflect current page?
Thread begun 6/08/2009 9:36 am by dennis-dunnwald325143 | Last modified 12/29/2010 9:39 am by jk419811 | 4319 views | 5 replies |
How do you change the color of the global navigation to reflect the current page that you are visiting. Is this done with CSS, if so how, or is some type of script that needs to be added?
Here is an example dermatology.stanford.edu/
Many thanks in advance for your help,
Dennis
There should be a checkbox option in the Menu Writer v2 user interface to do this for you.
Thanks Ray,
I found the check box.
Dennis
jk419811
Hi, I found this in the old threads. Every time I try to go back into the user interface everything gets all screwed up. Can you show me how to do this in the code?
Thanks!
Jennifer
It should be added to the javascript where your menu is created immediately below the menu html on the included page at the very bottom.
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { cssmw.intializeMenu('cssmw',{select_current: 1, orientation: 1}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { cssmw.intializeMenu('cssmw',{select_current: 1, orientation: 1}); }, true); }</script>
The select_current argument will be set to 0 for a menu that doesn't highlight the current page.
jk419811
That totally worked!
thanks!
Jennifer
