uk format phone number
Thread begun 8/19/2010 1:59 am by i.edwards384429 | Last modified 8/19/2010 1:37 pm by Jason Byrnes | 1769 views | 3 replies |
i.edwards384429
Hi
I thought this was the correct format to set the phone number format but it fails
<tr>
<th>Phone Number:</th>
<td><span id="sprytextfield4">
<input name="UserPhone" type="text" class="WAATKTextField" id="UserPhone" onBlur="if (document.getElementById('PhoneServerValidation')) document.getElementById('PhoneServerValidation').style.display='none';WAValidatePN(document.getElementById('WAATKRegistrationForm').UserEmail,'- Invalid phone number',false,true,'(xxxxx) xxxxxx',document.getElementById('WAATKRegistrationForm').UserEmail,0,true)" value="<?php echo(ValidatedField("usersRegistration","UserPhone")) ?>" size="32" />
<span class="textfieldRequiredMsg">A value is required.</span><span class="textfieldMinCharsMsg">Minimum number of characters not met.</span><span class="textfieldMaxCharsMsg">Exceeded maximum number of characters.</span></span>
if (ValidatedField("usersRegistration","usersRegistration")) {
if ((strpos((",".ValidatedField("usersRegistration","usersRegistration").","), "," . "13" . ",") !== false || "13" == "")) {
if (!(false)) {
<span class="textfieldServerError" id="PhoneServerValidation">
Please enter your phone number. </span>
<?php //WAFV_Conditional users_Registration.php usersRegistration(13:)
}?></td>
</tr>
var sprytextfield4 = new Spry.Widget.ValidationTextField("sprytextfield4", "phone_number", {format:"phone_custom", useCharacterMasking:true, pattern:"(00000) 000000", isRequired:false});
what have I missed?
thanks
Ian
change:
<input name="UserPhone" type="text" class="WAATKTextField" id="UserPhone" onBlur="if (document.getElementById('PhoneServerValidation')) document.getElementById('PhoneServerValidation').s tyle.display='none';WAValidatePN(document.getEleme ntById('WAATKRegistrationForm').UserEmail,'- Invalid phone number',false,true,'(xxxxx) xxxxxx',document.getElementById('WAATKRegistration Form').UserEmail,0,true)" value="<?php echo(ValidatedField("usersRegistration","UserPhone ")) ?>" size="32" />
to:
<input name="UserPhone" type="text" class="WAATKTextField" id="UserPhone" onBlur="if (document.getElementById('PhoneServerValidation')) document.getElementById('PhoneServerValidation').s tyle.display='none';WAValidatePN(document.getEleme ntById('WAATKRegistrationForm').UserEmail,'- Invalid phone number',false,true,'',document.getElementById('WAATKRegistration Form').UserEmail,0,true)" value="<?php echo(ValidatedField("usersRegistration","UserPhone ")) ?>" size="32" />
i.edwards384429
Update
Hi Jason
I've clearly missed something out here because my attempts at Uk postcode and phone number both failed. I've had it workinmg before but now it's failed. Added your code and still no go.
I've attached the page in question if you get time can you take a look and tell me where I've gone wrong
thanks
Ian
for some reason, the phone number field is set to validate the useremail field as a phone number.
change:
to:
<input name="UserPhone" type="text" class="WAATKTextField" id="UserPhone" onBlur="if (document.getElementById('PhoneServerValidation')) document.getElementById('PhoneServerValidation').s tyle.display='none';WAValidatePN(document.getEleme ntById('WAATKRegistrationForm').UserPhone,'- Invalid phone number',false,true,'',document.getElementById('WAATKRegistration Form').UserPhone,0,true)" value="<?php echo(ValidatedField("usersRegistration","UserPhone ")) ?>" size="32" />
