Framework with CSS Forms don't function as intended.
Thread begun 8/12/2010 10:36 pm by Jaffa | Last modified 8/18/2010 8:13 am by Ray Borduin | 6022 views | 10 replies |
Jaffa
I thought i'd create a standard set of contact forms and use them as includes using framework when i needed them but seems it won't work this way.
Create a standard php page with a ccs form in it and use the security options within the
form. Save it out.
Create a new php form and use the framework extension to include the contact form you made first in your new form.
Run and all looks great and seems to work as intended until you enter in a incorrect security code for the form. The form jumps out of the php page and shows the contact form by itself with thw validate warning on the screen.
Anyone shed any light how to keep everything in the on form or am i not doing something. Don't have an example to show you as i deleted it, but will re-create if required to demo what i need.
Cheers
Russell CollinsBeta Tester
Hi Jaffa,
Have you tried using a dynamic plug-in and not static ?
Russ
Hi Jaffa... It sounds like it should work... I'd love to look into it with you. If you could zip up the files and attach them I can try to reproduce it myself.... or if you email me ray@webassist.com and let me know a good time and phone number to reach you we can do some screen sharing and I'll debug it with you directlly.
Jaffa
Files attached
OK, I recreated the files using a a very basic shell in order to only show the WA extension files and code. If you run this you will see that all works as intended until you enter in an incorrect Security Code, this is when it jumps out of the form.
Any insight into why this would happen would be appreciated. I see no reason why using a dynamic plugi would be required in this case as I'm calling the form directly.
Cheers.
In order to fix the problem you need to update the redirect setting for the server validation on the contact_basic.php page.
By default the form redirects to itself, which in this case redirects to the plugin and not the page.
Update line 5 of contact_basic.php to from:
$WAFV_Redirect = "contact_basic.php?invalid=true";
to:
$WAFV_Redirect = "" . $_SERVER["PHP_SELF"] . "?invalid=true";
That should fix the problem. We'll probably have to update form builder's server validation to use that code automatically so that it will work better with plugins by default in the future.
I tried correcting line 5 but made no difference to Jaffa's example.
I made a few pages of my own and corrected the redirect but still made no change to the problem.
Russ
Yes... sorry I forgot that the page name is also referenced in the form action:
on iline 133 you would also update the other page reference to use the php_self server variable so that it would be portable as a plugin.
action="contact_basic.php"
becomes:
action="<?php echo($_SERVER["PHP_SELF"]); ?>"
Jaffa
The 2 changes corrected the initial problem but the redirect to the thank you page still has issues, Object not found error.
I see. The issue here is that framework builder automatically updates any links that occur in the html, but can't update the server redirect page. This means that the path to the redirect page has to be relative to the page it is included on, and not the plugin itself.
The simple solution is to update line 32 where it says:
$GotToPage = "../thank_you_basic_form.php";
and make it say:
$GoToPage = "thank_you_basic_form.php";
That will make it work in this case, but hurts the portability of the code.... since you can not effectively plug it into any subdirectory pages.
A more elegant, though more complex solution would be to use a redirect like:
<?php echo(rel2abs("../thank_you_basic_form.php",dirname(__FILE__))); ?>
This will use the library file to convert the redirect link reference to be relative to the page it is plugged into. This slightly more complex syntax should keep the plugin fully portable, and could be similarly used in other server behaviors when applied to plugins.
We will likely account for this in future versions of the extensions now that the framework builder is released.
Jaffa
Thanks for the workaround. If I use relative path to absolute path so that the redirects work what effect will it have on the page once these types of bugs are sorted out?
Meaning once this is achievable within the framework extension do i have to uncode the changes in order to apply them correctly uisng the wizard.
The reason I'm asking is that I'm developing a complex application for a client, I'd hate to have to go in and re-write the modules.
Maybe i should go back to includes and wait for a stable version.
-Dave
