Insert records into multiple tables?
Thread begun 6/07/2009 2:06 am by cheongyap254819 | Last modified 6/07/2009 11:00 am by cheongyap254819 | 3432 views | 2 replies |
cheongyap254819
Hi, I'm newbies to Dataassist.
Just wanna ask is it possible to inject records into multiple tables in Dataassist at the same time?
I realised data assist only allow 1 table insert at a time.
How about if i'm dealing with Relational Database that uses foreign keys.
means i do have to insert the record 1 table by 1 table?
Joe Lowery
One of the differences between the server behaviors in DataAssist and the standard Dreamweaver ones is that with DataAssist, there is no limitation to the number of insert, update or delete server behaviors you can add to a page. So you can add one DataAssist Insert Record behavior for one table and another for a second table.
On relational tables, DataAssist contains a dedicated server behavior called Manage Relational Tables intended just for that situation.
Best - Joe
cheongyap254819
Thanks. This helps me a lot.
