tSelection has no properties?
Thread begun 8/04/2010 5:13 pm by elevy388997 | Last modified 12/19/2010 8:03 am by Miguel | 4984 views | 8 replies |
elevy388997Beta Tester
I get an error when generating my form in dreamweaver:
Error generating form:
TypeError: tSelection has no properties.
have you tried deleting the Dreamweaver cache file from the users configuration folder:
Yes, no changes.
Exact steps:
Click in my editable region on my contact page
Insert>Webassist>CSS Form builder
Contact>Saved Preset
Design saved preset
Finished
Error Generating Form:
can you export the saved presets you are using and attach them to your reply so I can try to reproduce the issue to look into the problem.
Here they are, thanks for helping out as usual!
login.php
Miguel
Im having the exact same issue
in a connect session we discovered this issue was happening when adding more than one form to a page.
one work around would be to use Framework builder, add each form to a separate page then incorporate them into a main page by adding them as framework items.
Miguel
awn thanks for the replay jason i kept trying cause i readed on other post we cna have more than one form on the same page but guess ill have to do the includes but the bad part of that means much more work now ill have to do the validations on difrently :(
