Validation of drop down menu with Digital File Pro Upload
Thread begun 6/04/2009 10:01 am by cal114936 | Last modified 6/09/2009 8:07 am by office377308 | 3473 views | 2 replies |
cal114936Beta Tester
I have a drop down menu inside the same form as the file field for Digital File Pro Upload. I have tried to apply a client validation for the menu as a required selection. But the validation doesn't work and the file upload starts. Any ideas why the validation might not work before the file uploads? testUpload.php
It appears there is a bug in the code for the function WAValidateRQ in the most recent version of validation toolkit when doing client validation on a select list.
The code:
if (formElement.length) formElement=formElement[0];
should be:
if (formElement.length && inputType.toLowerCase()!="select") formElement=formElement[0];
You can correct the problem manually for now. I will make sure it is fixed in the next update.
office377308
Thanks, same problem here
does it make a difference if there is no form action defined? Because I have filled out the redirection field in insert record server behaviour.
