incorrect encoding of £ symbol.
Thread begun 7/19/2010 12:08 pm by CraigR | Last modified 7/19/2010 1:25 pm by Jason Byrnes | 2696 views | 5 replies |
CraigRBeta Tester
Not sure where to put this, as although occuring in ecart, it isn't an ecart problem.
i have manipulated a few coupons to retreive various options from a database.
On adding 'saddle' as the voucher code, when a particular item is in the cart, a £25 discount is added.
The cart display object retrieves the text string from the database and displays it in discounts, when the code is entered, however the £ sign is not displayed propely. (it seems to work with $).
I have changed my table so that the data is utf8, but still no joy.
link to test page...
productdetail.php?ItemType=4&Item=54
just click on the add to cart button and type 'saddle' in the voucher box
does it show the pound sign correctly in the database?
if so, try adding the following at line 1 of your page:
ini_set
('default_charset''utf-8');
CraigRBeta Tester
hi Jason.
Yes, the £ is fine in the database.
I already have <meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> in the head of my page.
I added the line you suggested, but this seems to make no difference.
try adding that into the eCart coart object php file as well.
you may also need to set the client connection being used by php.
open the connection file in the connections folder, and find the last line, it will look like:
$<Connection Name> = mysql_pconnect($hostname_<Connection Name>, $username_<Connection Name>, $password_<Connection Name>) or trigger_error(mysql_error(),E_USER_ERROR);
where <Connection Name> is the name of the connection, add the following to the next line:
mysql_set_charset('utf8', $<Connection Name>);
CraigRBeta Tester
Hi Jason.
The edit to the database connection file works ! (at least on my local server).
Any more issues, I'll let you know.
Many thanks
--update, works on live server in testing area too ! :-)
awesome, glad to hear it's working.
