Dreaweaver CS3 freezes using Dataassist
Thread begun 6/04/2009 6:54 am by phil.evans372967 | Last modified 6/05/2009 8:03 am by Ray Borduin | 3415 views | 6 replies |
phil.evans372967
Hi all
I'm trying to use dataassist wizzard with a dreamweaver cs3 template (attached) but CS3 freezes when I get to step 2 - select layout options.
Can any one help?
Phil
roby258376
I'm certainly no expert when it comes to DataAssist but I had a similar problem with DW4 and the fix was to run the DataAssist wizard using a local server rather than a live one.
phil.evans372967
Hi - thanks, but I'm running it on a local dev machine. The wizzard runs OK if I don't use a template
Please post a support incident. This is not a known issue and we will need to have someone work with you to try to reproduct it.
phil.evans372967
Hi Ray
I've posted a reply but had no response as yet.
Phil
phil.evans372967
Sorry, I meant to say I've raised a support ticket
What is your incident number? Our head of support is out on vacation, so we have been a little behind schedule but response times seem to have still been reasonable. What is your incident number I can look into it further to make sure it is getting some attention.
