How to pass child list value to next page?
Thread begun 7/16/2010 5:39 pm by jeffmg279672 | Last modified 7/21/2010 10:36 am by Dave Buchholz | 7975 views | 27 replies |
jeffmg279672
Attached zip contains 2 pages - review_add.php which contains the dynamic dropdowns, and add_review.php. I want to be able to make a selection from the parent list, then select from the child list (which all works fine) then pass the selected item from the child list into a text field on the second page when "Submit" is pressed. How can I do this?
Dave BuchholzBeta Tester
Assuming that you are talking about this field
<input name="vetname" type="text" id="vetname" value="<?php echo $row_Child['practicename']; ?>" size="35" />
then you need to filter your recordset by the value posted from the child select list on the previous page.
To do this open up your recordset in Dreamweaver in simple view and from the filter menu choose the id of the recordset then choose Form Variable from the drop down below that and type the name of your form field into the text box, in this case child. Save your changes and try it in a browser. the field vetname should now contain the practisename after the previous page is submitted.
jeffmg279672
Many thanks, Dave - that really helped, now working fine, thanks. I now need to get the rest of the fields on that second page inserting to the db and all will be good. Appreciate your assistance.
no worries, it really is easy once you know how.
for database inserts you can use the data assist wizard available in the server behaviours panel or the standard dreamweaver insert behaviour, either will get you going.
jeffmg279672
I thought I'd give it a whirl and add some insert behaviours as suggested, so created two more recordsets - one for the comments to insert into my reviews table, and the other to insert the reviewers' details into the reviewers table. I then tried testing it locally and I got a fatal error message; a quick search on here indicated that the include call for the DA App Builder file had been inserted too low down the page - it had, so I moved it up under the include call for the Connections file. I ran through the add review procedure using my local server, and the review was added to the db and I was redirected to the "thanks" page as anticipated, so I thought I'd cracked it, so I tried adding a second review, and got this error:
Duplicate entry '0' for key 2
I had no idea what this meant, so I searched on here and decided that it had something to do with the fact that the practice_id number is being added to the table as '0' each time, which is why the second review wasn't added. In other words, the practice_id isn't being passed through, which means that the review isn't linked to the correct practice, so I need to sort that somehow. I presume this is a similar thing to needing to pass the child list value (above)? I've just manually added the correct practice id number to the reviews table, and then added another dummy review and it's inserted that into "reviews" perfectly, but again with the practice_id '0'. Any suggestions how to ensure that the correct practice_id is pulled from the parent/child drop-downs and inserted into the "reviews" table?
post your current pages and I'll have a look and see if I can point out where you are going wrong
jeffmg279672
Thanks Dave, attached zip contains the page with the drop-downs and the page that's giving me trouble. Wasn't sure if you wanted the db as well so have included that in the zip file.
I'll take a look in the morning for you
jeffmg279672
Many thanks, appreciate it.
Originally Said By: jeffmg279672
Jeff,
you are correct the error you are seeing is due to the fact that you are not inserting the practise_id into the table reviews, to solve this issue add a hidden field to your current form like so:
<input type="hidden" id="practiseID" name="practiseID" value="<?php echo $_POST['child'];" />
and then use this form in your database insert.
There is potentially another issue though as you have a field reviewers_id which will never get a value the way you have things set up currently as the standard dreamweaver database insert doesn't have an inbuilt method of creating a variable (session or global) that you can use to get the reviewers id from the insert into the reviewers table. It is possible to hand code a solution to this but I suspect that would not be your preferred option so if you have data assist you can get around this very easily by using the data assist insert server behaviour to do the insert to the reviewers table first with a blank redirect, this creates a session variable for the id of the record created that you can then use in the 2nd insert to the reviews table.
Hope that makes sense.
