null value
Thread begun 6/04/2009 5:01 am by roby258376 | Last modified 6/04/2009 8:12 am by roby258376 | 4387 views | 8 replies |
roby258376
null value
Hi all,
I am trying to figure out how to do something and I'm hoping someone here can tell me how.
I need to show records based on:
1) authorization level = 7
2) the person belonging to committee 1 or committee 2.
If I go into the database and manually set each database record to null for committee_ID and committee_2_ID (unless of course they are on a committee) the following works.
SELECT *
FROM members
WHERE members.auth_ID=7 AND members.committee_ID is not null AND members.committee_2_ID is not null
but I cannot get the db fields for committee_ID and committee_2_ID to default to null if no committee is entered when a member is inserted or updated. So new members and any members who are edited to take them off a committee, is still showing up in my search.
any help is appreciated.
xag
Why not just get all memembers and use Secruity Assist Show region to handle it? Make a rule and bam your done. That is what I do throughout my whole site... just made a ton of rules and use session variables to see if a user signed in and what their credentials are then show a region if not don't show it.
roby258376
The list is viewable by all, so I don't think that would work. What I need to know is how to set a field in the database to the actual value (null), if no other value is entered, or if an empty value is entered.
I just can't find anywhere that tells me how to do that.
xag
Make the default value/binding in the DB (N'Null') so if there is nothing inserted it will be Null
roby258376
That's what I'd like to do, but I don't know how. What steps do I need to take to make the default value null instead of empty?
xag
well what version os SQL are you using? go into your table design and in the coulmn properties panel under General there is a place where you can insert Default Value or Binding
roby258376
Hi again,
I set the default value as (N,'Null') and then tried (Null), ('Null') and anything else I could think of. They all result in the db field being empty which is not what I need, I need it to actually have the (null) value inserted, so that not null works. Any suggestions?
xag
well if you put it in your defult binding just as null it should show up but not if you are inserted something. The last idea i have to work around it is to have a default hidden field set to Null and just insert that into your DB when no other input is inserted with DA
roby258376
Thanks for the info, I really appreciate the help.
I ended up setting the default value in the form field to a blank space, and rewriting my query to != ' '. that seems to have done the trick.
