lastLogin not working
Thread begun 7/13/2010 7:38 pm by mike372863 | Last modified 7/14/2010 11:49 am by Jason Byrnes | 1873 views | 3 replies |
mike372863
Hi
I added a db field 'lastLogin", added it to login form as a hidden field and added server behavior but it wont updated db. Can you look at code and see what Im missing? the login works fine and so does registration.
thx
mike
the security assist authenticate user behaviors that are on the page are set to redirect to the welcome.php page after loging in. That redirect occurs before the update can happen. remove the redirect from both of the security assist authenticate user behaviors to allow the update record behavior to trigger.
mike372863
thanks
crap! should have seen that. i just moved it up before the authenticate and it worked
THX!!
you're welcome.
