Equal Columns
Thread begun 6/03/2009 3:47 pm by Travis250923 | Last modified 9/24/2009 12:08 pm by Eric Mittman | 4903 views | 5 replies |
Travis250923
Equal Columns
So any suggestions for making equal columns? I know I can use the faux column technique but looking for alternatives. I've tried the PVII script (index.htm) but that requires something like <p> tag where there may not be one.
I also tried the one from dynamic drive (P0/) but that freaks out in IE.
Any other thoughts? If not I'll go back to the faux columns but was hoping for a better solution.
Justin Nemeth
CSS Sculptor has a built in faux column creator. You can just specify your css like normal, and it will automatically create an image and apply it for you. Would something like that work for your project?
Travis250923
That's in the latest version of the sculptor right? I have an older version that I think doesn't contain that feature.
That is correct. That feature was added in the most recent release.
keith309207
Faux Columns
Hi I am using faux columns with Version 3. Works perfectly, except for Firefox.
Am using 3.5.3
Any ideas on how to make it work on both browsers?
With the newest version of CSS Sculptor you should be able to check the box for equal column lengths in the interface to have it make them the same length. I tested this in FireFox 3.5.3 and was able to confirm that it seems to be working correctly.
Are you using the newest CSS Sculptor v3? Please post back and let us know what version and layout you are working with so we can help determine what is going on. If you have a link or a screen shot that would also be helpful.
