error
Thread begun 6/29/2010 12:08 pm by i.edwards384429 | Last modified 6/29/2010 5:47 pm by Jason Byrnes | 2121 views | 3 replies |
i.edwards384429
error
Hi
Ok I know i've modified the form (attached)
But can someone take a quick look.
Both the telephone and postcode fields, when I fill them in the dreaded yellow triangle appears bottom left saying there is an error
All works just dont like the error
thanks
Ian
can you send a link where I can see the problem to get a better idea of the cause.
i.edwards384429
link
Hi Jason
here's a link
users_Registration.php
thanks
Ian
the phone number field is set to use client validation on a form element that does not exist:
<input name="UserPhone" type="text" class="WAATKTextField" id="UserPhone" onBlur="if (document.getElementById('PhoneServerValidation')) document.getElementById('PhoneServerValidation').style.display='none';WAValidatePN(document.forms[0].S_ProductName,'- Invalid phone number',false,true,'x (xxx) xxx-xxxx',document.forms[0].S_ProductName,0,true)" value="" size="32" />
should be:
<input name="UserPhone" type="text" class="WAATKTextField" id="UserPhone" onBlur="if (document.getElementById('PhoneServerValidation')) document.getElementById('PhoneServerValidation').style.display='none';WAValidatePN(document.forms[0].UserPhone,'- Invalid phone number',false,true,'x (xxx) xxx-xxxx',document.forms[0].UserPhone,0,true)" value="" size="32" />
I cant reproduce an issue with the postal code.
