Page Refresh after Validation Error
Thread begun 6/29/2010 7:44 am by carlene311744 | Last modified 7/19/2010 6:43 am by Jason Byrnes | 2811 views | 3 replies |
carlene311744
I have set up my client side validation. If any of it fails, the validation error box shows, but then after fixing the problem on the form, my submit button doesn't seem to work. It is as if it is just stuck. I do have a private captcha on the form, which needs to be refreshed, but I can't figure out how to get the page to refresh after the validation error form appears.
Do you have a script that disables your submit button after it is pressed once? You would need to add a script to enable the button again after if you do have something like that set up.
The form or activation shouldn't automatically be disabling the submit button however. If you could post up the url for your form I would be able to look into the issue better.
mr hankey
hi,
i have the exact same issue. the insert record button goes like greyed out. you cannot click it after fixing the errors. this is using the clientside validation.
no other script on page using a disable button method.
just data assist insert record and validation toolkit. i have multiple forums on the one page, not sure if the carlene311744 has this also that might be the issue??
thanks
please send a copy of your page so i can examine the code.
