Customize CSS always reverts back to the first item in the list
Thread begun 6/28/2010 10:52 am by sandy170299 | Last modified 8/16/2010 7:05 am by Jason Byrnes | 6144 views | 15 replies |
sandy170299
This is what I am doing:
1. I am choosing a design type (2 column fixed, left sidebar, header and footer)
2. I am choose a design (slate)
3. it appears correctly in my preview
But when I choose Customize CSS, it selects the first design in the list, which happens to be a custom layout of mine. No matter which design I choose from the list, it always reverts back to the first one and brings that design up for modification.
Yes, I am using the latest version of CSS Sculptor.
I will attach an updated copy of the wacs_quickinsert.js file that you should replace your current one located here:
C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver 9\Configuration\Commands
Note, the path will be different for different Dreamweaver versions and Operating systems. To find the Configuration directory, you can follow the steps outlined in the common installation issue:
sandy170299
Perfect. Thank you!
nancy19533
style reverts back to Cabo ..
I just downloaded the CSS Sculptor today and am having the same issue. I customize the colors out the wazoo and lose them all the second I click back into the CSS to make changes .. it goes back to Cabo (first on the list) with default colors and everything I did is gone.
Very annoying .. I really hope this is because I don't know what I'm doing with this thing .. at this point, I'm tempted to return it. :(
Originally Said By: nancy19533
Did you follow the steps I outlined in my first response to the thread? We are working on getting a release to fix this issue, but it is still in the testing phase.
nancy19533
deleting the wincache? Yes, I did that .. it seemed worse after I did so, but that might be my imagination. I can easily choose to create a CSS Sculptor page, select any layout other than Cabo and the second I click on Customize CSS, I can see it change back to Cabo in the window. Every time.
Unfortunately, this makes the extension unusable and now that I find out it was a known issue, I feel a bit disgruntled that you are selling it anyway.
Feel free to put me on the testing team .. I have done this sort of thing for years on various products and extensions.
I believe there is only a 15 day window for a refund. Obviously, the issue needs to be fixed with ample time after the fix is finished for user testing before the refund window is closed. If such is not the case, refunds are definitely in order.
Justin Nemeth
Jimmy posted a file above that will fix the issue. Follow his steps on how to replace it and the issue will be fixed.
-justin
sandy170299
Actually, I just noticed that the "fix" deleted all of my saved presets. How can I get them back now, or are they lost for good? Bummer...
Justin Nemeth
Jimmy's fix shouldn't affect the presets at all since its just a single file. Have you checked the preset manager to see if they are still listed there?
sandy170299
Most of them are gone - only one preset that I created and saved is in the list. All the rest (probably four of them) are gone.
