How do I create a double opt-in?
Thread begun 6/27/2010 10:53 am by mrs | Last modified 7/24/2013 9:26 am by Jason Byrnes | 14794 views | 28 replies |
mrs
I am looking to create a user registration page that enables me to then send a confirmation email, and within that, I want to have a link that the user has to click to confirm the email is correct. I am sure this is called double opt-in.
I was told how to do it in a rough manner by Jason when he gave me a tech support call, but I can't for the life of me find the pad I wrote it down on! I think I recall having to use data assist, universal email and security assist and having a column in my table that registers the click from the email, but I just don't know how to go about setting this up.
Can somebody please advise? I have pretty much all of the extensions available, so if I could have a step by step guide here, I'd really appreciate it. Would form builder be of any use, I have that too?
Mat
the basic steps for double opt in are:
database:
you need to add 2 new columns to the users table:
randomString - text
emailVarified - int. default value 0. will be updated to 1 when the user verifies the email
Registration:
On the registration page, use the security assist random password feature to create a random string Store the random string in a session variable.
In the insert Record behavior, set the new randomString column to use the session variable value.
The Insert record behavior will store ID of the new record in a session variable, make note of the session variable name in the Store As section of the Insert Record behavior.
Registration Email:
the registration email will have a link to the usrConfirm page. this link will pass the UserID session variable and the random string session variable as querystring variables:
userConfirm.php?id=<UserID Session value>&randomString=<random string session value>
userConfirm.php:
The userConfirm.php page will have a recporset to filter the userID column on the ID querystring value and the randomString column on the randomString querystring value.
also an Update record behavior that is triggered if the recordset is not empty to update the emailVarified column to 1.
Login:
On the login page, edit the authenticate user behavior, On the second step, click the plus button to add another condition. Select the emailVarified column and set the value to 1.
This will cause login to pass only if the emailVarified gets updated to 1.
The User registration solution pack uses this method. If you examine the registration process in the User Registration solution pack, It will demonstrate how this is all put together.
info22862
Matt, Where you able to create this fuctionality?
Do you have any pointers for those who are attempting to do the same?
mrs
No, I tried to convince a few customers to implement it, but they seem to want to manage their users manually, so sadly, I have never been able to try it.
I hopefully have some projects coming up where the volume of traffic is going to mean that the site has to have this implemented, so if I do manage to get it up and working, I'll let you know. On the other hand if you succeed before I do, let me know.
Jason's explanation is quite concise.
info22862
Thanks for your quick response.
Yes, we'll definately be creating this functionality so I will post our experience once we create it.
PS: Interesting that the captcha used here is not the same as what Web Assist offers in their Forms Toolbox.
Actually most of the web assist website is not built with Web Assist technologies.
IE: Jquery, AJAX, Forms and captchas. I like their tools, but curious as to why they don't "Eat their own dog food".
Jerry
info22862
Files not being generated
Jason
When I run either the random password or password encryption functions the associated php files that are supposed to be created are not. They are not in the folder as WA defines them in the require_once path.
../../WA_SecurityAssist/WA_RandomPassword.php'
Any thoughts?
Thank you -
this is an issue some people are running into, see this post for a copy of the files that should be created in the WA_SecurityAssist folder:
showpost.php?p=13143&postcount=2
danny405167
I need a little help
I am following the steps on how to to create a double opt-in. So far everything is going smoothly but I am stuck on how to update the emailVarified column from 0 to 1.
This is what I have in my wizard page:
EVENT
Trigger: Recordset: Recordset 1 is not empty
DATABASE
Connection: bm_printing
Table: users
RECORD
Key Column: userID
Value: ???????????? Do I use my session variables
Data Type: Numeric
danny405167
I got it. Thanks for the easy to use instructions.
you're welcome
