getTagProp not defind
Thread begun 6/25/2010 7:44 am by John Langer | Last modified 1/03/2011 6:31 am by Jason Byrnes | 7361 views | 22 replies |
John LangerBeta Tester
This was happening with CT312 installed. I've just installed v313 and still get the error.
If I try and run the behaviour "Clear Session Values" I get a warning dialog box that says:
"While executing onLoad in WACT_ClearSession.htm, the following JavaScript error(s) occurred:
At line 357 of file
"C;\Users\John\AppData\Roaming\DreamweaverCS%\en_US\Configuration\Shared|WebAssist\Cookies\Library\WA_configuration.js":
getTagProp is not defind"
I've deleted the WinCache file and recreated it. I don't really want to recreate the Configuration folder unless it's absolutely necessary and, as I've said, I've uninstalled Cookies toolkit 312 and installed CT313.
Line 357 of that file says, " return [getTagProp(tXML, "macromedia-extension", "name"), getTagProp(tXML, "macromedia-extension", "version"), getTagProp(findTag(tXML, "author", true), "author", "name")];"
Any ideas?
Unfortunately it looks like there is another extension that is interfering with that server behavior. You will have to delete the configuration directory to get around it currently. We'll have to do some more testing to look into which extension is causing the interference.
paulshoe379536
I too am having the same problem (capture of error dialog attached).
I have uninstalled all 19 of my WebAssist extensions and reinstalled. I did not uninstall extensions from other sources. This did not resolve the issue. Unfortunately, it takes a lot of time to uninstall and re-install extensions. I hoping there is a solution that will not require me to do this again.
Using "Set Cookie Values" works.
When I access "Set Session Values" it launches the "eCart" activation screen.
Originally Said By: Jimmy Wu
Thanks for the reply Jimmy. Are you actually looking into this now, or is it something for the future? I'f it's now, I'll hold on for a fix as deleting the config folder is a real pain, and if it's another extension interferring then it's likely to return anyway.
Its something we're looking into for a future release, since it will take quite a bit of QA time to determine which extensions are causing the issue.
OK Jimmy, thanks for the feedback.
Just off the top of my head (and I could be wrong) I'm sure CT worked fine until I installed Site Sculpture. Just an idea of where to start looking...
I'll leave things as they are until I really need that part (clear sessions) of the CT extension.
Thanks for letting us know your experience. It'll definitely help with determining the cause if Site Sculptor is the cause.
mrs
Just to confirm, I am getting this error and I too have site sculptor.
Have you tried uninstalling both CT and SS, and then just installing CT again? I think I am going to try this, but just a thought!
I'll let you know if it makes a difference. And another thought; during initial installation of CT, I had a message that said an newer version of something or other existed, but, CT's update to CS5 came a few days after SS was released. Don't know if that's useful...
Thanks for that feedback. If uninstalling like that fixes the issue, please post back and let us know.
weboholic
I have cleaned the user folder in roaming (win 7) and installed cookie toolkit, universal email and security assist in this order. After installing security assist cookie toolkit stop working with the known issue. I hope this helps to uncover the bug.
