Captcha text color
Thread begun 5/31/2009 9:11 am by warrenphillips25336771 | Last modified 6/02/2009 10:53 am by Ray Borduin | 4938 views | 7 replies |
warrenphillips25336771Beta Tester
Captcha text color
Alright, so I went to the WA globals file, changed everything as i needed, but the captcha text is coming up yellow even though i specify it to be black, and when i try to change the color it just does not show. Am i missing something here as this only seems to have happened since updating the files
What did you update the value to? Did you include the #? You shouldn't.
Hi Ray
I just changed the values i normally do to "ffffff" I will attach the copy of the globals file for you to see
$WAGLOBAL_Captcha_Width = "200" ;
$WAGLOBAL_Captcha_Height = "40" ;
$WAGLOBAL_Captcha_Characters = "5" ;
$WAGLOBAL_Captcha_Font = "Fonts/MOM_T___.TTF" ;
$WAGLOBAL_Captcha_BG = "ffffff" ;
$WAGLOBAL_Captcha_Noise = "FFFFFF" ;
$WAGLOBAL_Captcha_Text = "000000" ;
$WAGLOBAL_Captcha_BG_transparent = "0" ;
$WAGLOBAL_Email_Server = "" ;
$WAGLOBAL_Contact_Email_Subject = "Online Contact Form Response" ;
$WAGLOBAL_Contact_Email_To = "enquiries@photographermanchester.net" ;
$WAGLOBAL_Contact_Email_CC = "warrenphillips25@googlemail.com" ;
$WAGLOBAL_Contact_Email_BCC = "" ;
If you look at the website contactus.php the text is yellow.
It looks like you may have updated the file:
WAVT_CaptchaSecurityImages.php
because it appears to always be yellow now. Usually viewing that file would have black by default, so I'm not sure why. I would look at that file and see if it was edited from the original.
Ray
tried that, even added new files, still the same problem, what could it be?
It sounds like it has to be an issue with that file. Did you edit the code?
no ray i did not touch that code, all my other sites work like they should, and they are all on the same server host to
Please post a support incident. I haven't run into this issue so we will need to have someone debug it with you to figure out the cause.
