UE Not Sending Emails
Thread begun 5/29/2009 11:44 pm by karen.marley367377 | Last modified 6/01/2009 7:11 am by Ray Borduin | 2369 views | 1 replies |
karen.marley367377
Hi I am having trouble sending emails from the Members_EmailPW.asp
Am using ASP Javascript and the error message after submitting the page is as follows:
Server object error 'ASP 0177 : 800401f3'
Server.CreateObject Failed
/WA_Universal_Email/Mail_JS.asp, line 33
800401f3
The code from this file is as follows:
var gBodyFormat = "";
var gOneToAddress = false;
function WAUE_AddAttachment(mailObj,attPath) {
if (WAUE_isAttachment(attPath)) {
mailObj.AddAttachment(attPath);
return mailObj;
function WAUE_SetCharset(mailObj,charSet) {
if (charSet=="us ascii" || charSet=="ISO-8859-1") {
if (charSet=="us ascii") {
mailObj.CharSet = 1;
else {
mailObj.CharSet = 2;
else {
mailObj.CustomCharSet = charSet;
return mailObj;
function WAUE_AddBCC(mailObj,bccEmail) {
if (bccEmail != "") {
var bccArray = WA_getEmailArray(bccEmail);
for (var bcc=0; bcc < bccArray.length; bcc++) {
if (String(bccArray[bcc][0]).indexOf("@")>=0) {
if (WAUE_isEmailAddress(bccArray[bcc][0])) {
mailObj.AddBCC(bccArray[bcc][1], bccArray[bcc][0]);
else {
if (WAUE_isEmailAddress(bccArray[bcc][1])) {
mailObj.AddBCC(bccArray[bcc][0], bccArray[bcc][1]);
return mailObj;
function WAUE_AddCC(mailObj,ccEmail) {
if (ccEmail != "") {
var ccArray = WA_getEmailArray(ccEmail);
for (var cc=0; cc < ccArray.length; cc++) {
if (String(ccArray[cc][0]).indexOf("@")>=0) {
if (WAUE_isEmailAddress(ccArray[cc][0])) {
mailObj.AddCC(ccArray[cc][1], ccArray[cc][0]);
else {
if (WAUE_isEmailAddress(ccArray[cc][1])) {
mailObj.AddCC(ccArray[cc][0], ccArray[cc][1]);
return mailObj;
function WAUE_AddRecipient(mailObj,recEmail) {
if (recEmail != "") {
var recArray = WA_getEmailArray(recEmail);
for (var rec=0; rec < recArray.length; rec++) {
if (String(recArray[rec][0]).indexOf("@")>=0) {
if (WAUE_isEmailAddress(recArray[rec][0])) {
mailObj.AddRecipient(recArray[rec][1], recArray[rec][0]);
gOneToAddress = true;
return mailObj;
function WAUE_BodyFormat(mailObj,bodyFormat) {
if (bodyFormat == 0) {
mailObj.ContentType = "text/html";
else {
mailObj.ContentType = "text/plain";
gBodyFormat = bodyFormat;
return mailObj;
function WAUE_Definition(remHost) {
var retVal = Server.CreateObject("SMTPsvg.Mailer");
if (remHost != "") {
retVal.RemoteHost = remHost;
return retVal;
function WAUE_SendMail(mailObj,mailAttachments,mailBCC,mailCC,mailTo,mailImportance,mailFrom,mailSubject,mailBody) {
if (gOneToAddress) {
var fromArray = WA_getEmailArray(mailFrom);
mailObj.FromAddress = fromArray[0][1];
if (fromArray[0][0] && fromArray[0][0] != "") {
mailObj.FromName = fromArray[0][0];
if (gBodyFormat == 2) {
var WA_Boundry = "----xxxxxx";
var WA_TextHeader = "--" + WA_Boundry + "\r\n" + "Content-Type: text/plain;" + "\r\n" + "Content-Transfer-Encoding: 7bit" + "\r\n" + "\r\n";
var WA_HTMLHeader = "--" + WA_Boundry + "\r\n" + "Content-Type: text/html;" + "\r\n" + "Content-Transfer-Encoding: 7bit" + "\r\n" + "\r\n";
var WA_Footer = "--" + WA_Boundry + "--" + "\r\n";
mailBodyArray = mailBody.split("<multipartbreak>")
mailBody = WA_TextHeader + mailBodyArray[0] + "\r\n" + WA_HTMLHeader + mailBodyArray[1] + "\r\n" + WA_Footer
mailObj.ContentType = "multipart/alternative; boundary=\"" + WA_Boundry + "\""
mailObj.Subject = mailSubject;
mailObj.BodyText = mailBody;
if (!mailObj.SendMail()) {
Response.Write(mailObj.Response);
Response.End
return mailObj;
function WAUE_SetImportance(mailObj,Importance) {
var newImportance = parseInt(Importance);
var newPriority = 3;
if (isNaN(newImportance)) {
if (Importance.toUpperCase() == "HIGH") {
newPriority = 1;
if (Importance.toUpperCase() == "LOW") {
newPriority = 5;
else {
newPriority = newImportance;
mailObj.Priority = newPriority;
return mailObj;
With the line that generates the error as follows:
Please Help! X
This means that the email COM object you have selected to use for the email is not installed on the server you are running the .asp page from.
