Hepl! Menu behind content footer photo
Thread begun 5/29/2009 1:26 pm by info374483 | Last modified 5/29/2009 3:04 pm by Ray Borduin | 2770 views | 2 replies |
info374483
I viewed this in XP and it worked fine. But when viewing in Vista the contents bottom footer photo is not allowing the dropdown menu to show above the photo and causes the menu to cut off. Can you check it out? The website is www.bvscu.org. Do you have a quick fix?
Justin Nemeth
My guess is you need to set a higher z-index on the menu ul.
What version of menu writer are you using? This is most likely a z-index issue, but I thought it was corrected in the most recent version of menu writer.
