Set Zoom Level?
Thread begun 5/29/2009 11:04 am by craig380901 | Last modified 8/19/2009 3:37 pm by Ray Borduin | 13109 views | 15 replies |
craig380901
Set Zoom Level?
I am new to google maps but can hack my way around a bit.
I am trying to get the map to zoom out to a specific point where I can see a bunch of property locations within a 15 mile radius of NYC. I have tried setZoom(x) in the wagmp_map_1() function as map.setZoom(10); but the map displays nothing. Is this correct location or do I need to setCenter first?
Thanks neat product so far.
Do you have a sample url I can look at. I can take a look and see what I can see.
craig380901
Thanks for the quick response.
bronx-map.html
Although I have taken the code out at this point.
Update: helps to read the docs:) - although I still don't seem to be zooming out...
map.setZoom();
should be right... where are you adding it?
try adding it right after: marker_5.openInfoWindowHtml(address_5.infowindowtext);
craig380901
I read the docs and it says to add setZoom after each instance of map.addOverlay? Sort of had it working. But can I just add it once?
Thanks!
craig380901
Back again this time I am using the recordset method of displaying address, no problem there. Just wondering how I can adjust the zoom level to see a wider view of these locations, and I assume I may need to adjust the center location as well.
Here is a new link
map.asp
Thanks!
It seems like you could add the .setZoom call after the last instance of .addOverlay and it should work.
craig380901
I get mixed results... Seems whatever value I put in I either get a view from outer space or no change at all... odd any ideas? Another thing is the map will not load at all in IE6 even before the change.
Thanks!
zuffster370186
Having the same problem with SetZoom
I have applied all code changes that are on this thread and the online documentation. The code that my page now displays has the setZoom() code after the map.addOverlay lines.
IE 8 is showing this 'Error on page':
Line: 1599
Char 1
Error: 'wagmp_map_3_obj.getPointByAddress(...)marker' is null or not an object
Safari also has a problem with the zoom just like IE. On Firefox, everything works great. I am assuming this is a browser conflict with the code.
In IE and Safari, with the zoom set to 14, I am still getting the view from Space.
fields.php
Please download and install the latest version of promaps. I believe you are experiencing some issues we have recently corrected that may account for at least some of the problems you are having.
Let me know once you have updated with the latest version and I can look into it further with you if necessary.
