Script error "running for a long time"
Thread begun 5/27/2010 2:17 pm by greenacres101280430 | Last modified 5/28/2010 3:27 pm by Jimmy Wu | 2198 views | 3 replies |
greenacres101280430
After opening Dreamweaver CS5, it freezes up after clicking on anything, and then I get this pop-up window (see attached). I am using SiteAssist 1.0.8. I've already tried deleting WinFileCache.dat, then tried uninstalling, reinstalling, and deleting the .dat file again; no luck.
I use Windows XP. Thanks in advance for any assistance in solving this problem.
I will attach an updated WA_SitePreferences.js file. Try replacing the existing file and see if it works. The file should be located here:
WinXP
C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver CS5\en_US\Configuration\Shared\WebAssist\CSSMenuWriter\Library
greenacres101280430
Thank you for the quick reply. File replaced as instructed; unfortunately the same pop-up window came up. Any other ideas?
This seems to be a rare issue with site settings that we haven't been able to reproduce. I have opened up a backend ticket to take a look at this issue with you. To check your backend ticket, log in to your account and check your support history.
