Dynamic Dropdown Does not work
Thread begun 5/26/2010 11:25 pm by svm4096251851 | Last modified 5/27/2010 10:38 am by Jimmy Wu | 1507 views | 1 replies |
svm4096251851
Hello,
I have not been able to get DD to work. it is intalled, but I cannot add it to a page
Getting an error pop up" At line 22 of the file "C:programFiles\adobe\adobe Dreamweaver CS4\configuration\serverbehaviour\ASP_VBS\WA Dynamic Dropdowns\Creat Dynamic Array.js": WA_checkMySerialNumber is not defined.
I have the entire suite and have been able to use the other componets without issue.
SVM
I am attaching an updated version of the Create Dynamic Array.js file which you should replace your current version located here:
WinXP
-DW8
--C:\Documents and Settings\<Your User Name>\Application Data\Macromedia\Dreamweaver 8\Configuration\serverbehaviour\ASP_VBS\WA Dynamic Dropdowns\
-DWCS3
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver 9\Configuration\serverbehaviour\ASP_VBS\WA Dynamic Dropdowns\
-DWCS4
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver CS4\en_US\Configuration\serverbehaviour\ASP_VBS\WA Dynamic Dropdowns\
Win Vista
-DW8
--C:\Users\<Your User Name>\AppData\Roaming\Macromedia\Dreamweaver 8\Configuration\serverbehaviour\ASP_VBS\WA Dynamic Dropdowns\
-DWCS3
--C:Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver 9\Configuration\serverbehaviour\ASP_VBS\WA Dynamic Dropdowns\
-DWCS4
--C:\Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration\serverbehaviour\ASP_VBS\WA Dynamic Dropdowns\
(Please note that <Your User Name> Should be replaced with the User name you use to log into your computer)
NOTE:
On Windows Computers, The AppData or Application Data folders may be set to be hidden.
To View Hidden Folders in Windows Vista:
1) In The Windows Explorer, Click the "Organize" button
2) Select "Folders And Search Options"
3) Select the "View" tab
4) Click the "Show Hidden Folders And Files" radio button.
To View Hidden Folders in Windows XP:
1) On the Tools menu in Windows Explorer, click Folder Options.
2)Click the View tab.
3) Under Hidden files and folders, click Show hidden files and folders.
