Surveyor doesn't show up in DreamWeaver after installation
Thread begun 5/21/2010 11:33 am by gail.bergan407744 | Last modified 5/25/2010 3:22 pm by Jimmy Wu | 3070 views | 5 replies |
gail.bergan407744
Hello - I just purchased and downloaded Surveyor for DW CS4. The Adobe Extensions Manager says it installed and is enabled. But when I reopen DreamWeaver and go to Window > Extensions, it's not there. What else do I need to do?
Check the Insert->WebAssist menu and see if it shows up there. The access points are listed at the end of the description in Extension manager if you want to check the other access points.
gail.bergan407744
Thanks for your help!
This did the trick - got it launched and activated. Many thanks,
Gail
gail.bergan407744
Great little extension; suggestions for next upgrade
Surveyor is a great little tool - just a few suggestions for the next upgrade:
1) have a checkbox where we can substitute Page Titles for file names when building the sitemap - renaming all files on a large sitemap is quite tedious
2) some of the built-in styles/designs don't indent everything properly; only a few showed the 3 levels of indention I wanted, so I was limited to just a few choices. Also, your Getting Started documentation needs to have a section on customizing the color scheme, etc. on these templates.
Otherwise, very happy with the product.
If you could post these in the Wishlist forum, that would be great. That's the forum to post suggestions on any of our products. Thanks.
