Digital File Pro
Thread begun 3/10/2009 2:18 pm by karen.marley367377 | Last modified 3/11/2009 8:11 am by Ray Borduin | 4528 views | 3 replies |
karen.marley367377
Digital File Pro
Please help! - Have followed the Digi Pro Insert Tutorial to the tee. The records update but the uploaded images do not - i.e. the filepath and name in the access database.
There are two file fields on the page and have dragged the debug option for both on the following link.
properties_insert.asp
Danilo Celic
I tried to upload two images (and filling in no other fields) and I get this message at the top of the page (without the dashes):
System reported this error:
007~ASP 0104~Operation not Allowed~
The most likely cause for this error is the incorrect setup of AspMaxRequestEntityAllowed in IIS MetaBase. Please see instructions in the requirements page of freeaspupload.net.
This message appears to be from a different upload component. Are you using Digital File Pro on this page and another component, or just the other component?
karen.marley367377
Originally Said By: danilo
I am using digi file pro for the image files and then WAInsert for the other fields...
This error appears to be created by a component created by: freeaspupload.net (you can see this in the error message).
You can submit a support incident to look into this further, but something else is happenning that you did not anticipate as it appears you are not using only Digital File Pro as you expect. Somebody would have to look at the code on the page to figure out what exactly the problem is.
