min date not sure the correct code
Thread begun 5/18/2010 9:14 am by Miguel | Last modified 5/21/2010 6:29 am by Jason Byrnes | 1710 views | 3 replies |
Miguel
Hello again im trying to validate a date field with a min date
i have try
$WAFV_Errors .= WAValidateDT(((isset($_POST["despachado"]))?$_POST["despachado"]:"") . "",true,"\b\d{4}-(1[0-2]|0[1-9])-([12]\d|3[0-1]|0[1-9])\b","strtotime(\"+1 day\")","",false,".*","","",true,2);
also have try
$WAFV_Errors .= WAValidateDT(((isset($_POST["despachado"]))?$_POST["despachado"]:"") . "",true,"\b\d{4}-(1[0-2]|0[1-9])-([12]\d|3[0-1]|0[1-9])\b","".(date(\\"Y-m-d\\", mktime(0, 0, 0, date("Y"), date("m"), date("d") + 1))) ."","",false,".*","","",true,2);
none work i have readed most post about it here all i need for a date YYYY-mm-dd is to avoid ppl submiting today or tomorrow date for now im trying that they are allow to submit if the date they chose is not today date but no idea how i thought it would work on the min date field but not sure the correct code any help please
how are you entering the code for the minimum date in the wizard? are believe the way you are entering it in the wizard is the issue.
In the wizard, put the following in the Min Date filed to return tomorrows date:
<?php echo(date("Y/m/d"mktime(0,0,0,date("m"),date("d")+1date("y")))); ?>
Miguel
at the end i placed it like this and it worked
<?php echo date("Y-m-d",mktime(0, 0, 0, date("m")  , date("d")+1, date("Y"))); ?>
OK, glad to hear it is working.
