JS Error When Trying to Use Extension
Thread begun 5/12/2010 11:14 am by admin140217 | Last modified 5/19/2010 5:31 pm by admin140217 | 5453 views | 12 replies |
admin140217
I'm getting an error message when I stry to start SiteImport, the following message comes up when I press go:
While executing onClick in WA_SiteTools_Progress.htm, the following Javascript error(s) occurred:
In file "WA_SiteTools_Progress":
ImportNew is not defined
This repeats every time I try to execute a site import.
How do I solve this?
admin140217
I should add
that I have tried the common fixes as described in the PDF. I am using DWCS4 on Vista Ultimate
Have you tried renaming the config folder and re-install the extension? Here are the steps you can take for this:
If you have already done this or get the same result after trying let us know and I will ensure that a ticket is opened for you so we can look into this more.
admin140217
I have not renamed the configuration folder Eric and would rather not, I have a lot of extensions and not all from WebAssist, renaming the folder would affect all of the extensions installed.
Isn't there another way, quite honestly the extension should work without having to rename the configuration folder in the program it's being used in.
Is this something that is specific to WebAssist products and their Javascripts? If I unistall all the WebAssist products and re-install them, would that help the issue?
Renaming the configuration folder will force you to remove all of the installed extensions, there is no way around this when dealing with the configuration folder. This is not our workaround, it comes directly from Adobe. Here is a link to a page with more info on this and some of the other troubleshooting techniques when experiencing js errors with DW extensions:
tn_19105.html
admin140217
Worked, then didn't
Eric,
I have done what you suggested and it worked at first and I was able to use the extention I wanted but then it went back to doing the same thing. Is it possible there is an issue with the extention or DWCS4?
admin140217
Here's what I have discovered
Okay, since this happened again, I again renamed the configuration folder and removed every single extension I had installed. All extensions were installed through the extension manager from a fresh download of the product.
I opened DW to make sure all was okay and it was.
I started by installing site import 3.0.3 and opened DW, activated the extension and all is okay. I even imported a website to test it.
I installed many other non WebAssist extensions and after every extension I installed I opened DW and opened Site Import...no errors with it or other extensions.
I installed WebAssist Universal Email 4, I got no overwrite message in the extension manager, opened DW, activated it just to get it going and then closed it. When I tried to open SiteImport 3.0.3 again I got the same error message that started this. The error seems specific to Site Import, when I open UE4, there is no error.
In this experiment I can only conclude that there is some kind of error in the WA extension(s) that is not allowing it to work well with it's sister extensions. Am I wrong given the process I just followed?
What's my next step?
Please help, I can not keep going through this!
I have opened a ticket so that we can look into this issue further, to update the ticket login and visit your support history area:
admin140217
updated ticket
Eric,
Thanks for opening the ticket, I did update the ticket information. long story short, I have nothing but WA extensions installed and although the Javascript error did not show right away as before, it did eventually.
It looks like there were a couple of issues going on. In the ticket you posted that you tried renaming the configuration folder and did not get the proper results after doing this. You then updated the ticket to say that after renaming the config folder you then had to delete the cache file to get things working without the js errors.
I noticed that there is no link to the steps for deleting the cache file so I'm adding the link here:
