DataAssist Error Message when trying to access wizard
Thread begun 3/10/2009 4:09 am by gwh362692 | Last modified 6/29/2010 1:35 pm by designate407706 | 4011 views | 4 replies |
gwh362692
Hi everyone,
I'm using DataAssist 2.04 on Mac OS 10.5.5. I've created a new dynamic php/mysql site and I'm trying to access the DataAssist Wizard. When I try to do this though, it's throwing back an error message:
DataAssist Wizard is compatible only for the following server models: ColdFusion, PHP, ASP VBScript, ASP JavaScript
Does anyone know why this is happening? I'm using PHP as the server model so I can't understand it.
Really appreciate any help.
Danilo Celic
Dreamweaver determines the server model from the current document you are working with. Do you have a PHP page open when you try to access teh DataAssist Wizard?
Make sure your page is saved into a site that is defined as having a php server model in the dreamweaver site definition. Also make sure the page has a .php extension.
That should fix the problem.
gwh362692
Oh yeah - I didn't have a php page open. That solved it. Thanks so much.
designate407706
PUT THIS IN THE DOCUMENTATION WEBASSIST: "Make sure you have a PHP page open when you try to access the DataAssist Wizard."
