running php in safe mode
Thread begun 5/05/2010 3:33 am by nylpaard307924 | Last modified 5/05/2010 7:55 am by Jason Byrnes | 1914 views | 3 replies |
nylpaard307924
I have purchased PoweCMS 2.0.0 and try to use it on my site.
If i want to install it on the site i get the message that PHP is running in safe mode.
I have connected whit my provider and they say that if they turn the safe mode off that I am responsible for the fact when the site get hacked en there is damige on the other sides.
It is a MySQL database that runs PHP in safe.
Is there a solution that i can use the newest PowerCMS on this server?
NO, there are a number of PHP functions that are used by PowerCMS2 that are disabled when the server is set to run in Safe Mode.
nylpaard307924
So if i do understand you correct i have nothing on your PowerCMS 2 under these conditions.
Because only now be heard and brands is a great pity, I had actually hoped to take advantage of PowerCMS 2.
PowerCMS Cannot be used on a host that is running in safe mode.
Safe mode must be turned of on the host to be able to use PowerCMS.
