Error Message when Dreamweaver Starts
Thread begun 5/24/2009 10:11 am by pcmait334571 | Last modified 5/25/2009 6:56 am by pcmait334571 | 3308 views | 2 replies |
pcmait334571
I have been trying to install DigitalFilePro 2 on my Macbook Pro. Although the Extension installs, when I start Dreamweaver CS3, I get an error message:
The following translators were not loaded due to errors:
WA_DFPProgressBar.htm: has configuration information that is invalid.
The extension installed ok on my work computer – Mac powerpc running OS X v10.4
My Macbook is running OS X 10.5.6
Is this a known issue? I tried installing/removing and reinstalling the extension at least 6 times. The older version DigitalFilePro 1.1.3 does not cause the error.
Any help greatly appreciated.
Paul
David StringerBeta Tester
Originally Said By: pcmait334571
Paul
Hi Paul,
Take a look at this and see if it helps you!
showthread.php?t=621&highlight=winfilecache.dat
pcmait334571
Hi David,
Thanks for the info. Worked a treat.
Paul
